Puller motor
Anonymous-0
Hi, I was just wondering if a set of 4232 heads would bolt up to a stock 403 engine, and if not what has to be done to make it work.
Thanks
We have 4232 heads on a G with 403 Engine. Yes they will bolt right on. If you are replacing the 4210 heads. If you are replacing the older, Taller heads, you might need to change the studs or use extra washers so you don't run out of threads before the nuts are tight.
Yes, I'm planning on using the 4232 as an upgrade over 4210's, is there anything else to look for or do to ensure it'll be an easy swap? And also, what would be a good price for a pair of the 4232 heads? Thanks
