Yesterday's Tractor Co.
Shop Now View Cart
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: GB and plow restoration
04-16-2013 17:18:48
To answer a couple of questions. First, I am not too familiar with G's. This one has a side mounted reservoir with hydraulic valve on top with check valves, so it can be used with a standard cylinder. I do not know if this is common for a G. My U and UB special have reservoir mounted on top of transmission and the valve is inside the reservoir and require a MM cylinder with check valves in the cylinder, as they are not part of the valve assembly. Second, as we will be using the tractor as a stationary power unit for an auger, clam shell fenders allow easier access to operate hand clutch and pto lever more safely while standing on the ground. Also, clam shell fenders were partly personal preferance. I thank you for your kind compliments. This was a fun father/son project.
