MM GVI or MF 95
Does a MF 95 have the same value as a GVI. Same condition, tires, etc. Apples to Apples comparison. It's a diesel. I know MM's but not a thing about MF's other than it is the same tractor with different sheet metal.
The MF95 is a tractor built by MM for Massey- Ferguson that was sold by MF in Canada. AS such: they are likely to be fewer of them in the U.S. than the GVI
The 95 was the same as a MM GBD (diesel only) and the 95 Super was a Gvi. Since there were less MFs built, they are probably worth a bit more.
I think all the 95 and super 95 were diesels. These Massey tractors are popular with tractor pullers because the HD 800 engine will bolt right up to the diesel flywheel. The Moline 705/706 was also painted as the MF 97 which was available in lp or diesel. I think more MF 97's were produced than the Moline versions (705 & 706) The 95's are probably more scarce than the MM GBD and GVI.
There were 100 MF 95 Super LP produced. Definitely not something you"ll see very often.
