TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: g1000 vitsa
Alan K
03-25-2013 19:51:45
I had problems with my G950 that the light stayed on (was that way when I bought it). I was told it was probably the filter screen that was plugged. When I got it apart the filter was fine but the transmission lube pump had a broken gear in it. I ended up replacing the pump and the driveshaft for it. My 950 I had to take the top cover off of the rear end but I think the Vistas and maybe the 900s have a plate underneath to accesss the filter, after draining the rear end I would imagine. If your pump was replaced it should be good. Did you test the pressure yet with a gauge where the sender is?
mm farms md
03-27-2013 08:47:27
 Re: g1000 vitsa in reply to Alan K, 03-25-2013 19:51:45
no not yet is there anyway the pump put on wrong shims or something like that thanks
Alan K
03-27-2013 11:19:05
 Re: g1000 vitsa in reply to mm farms md, 03-27-2013 08:47:27
I dont believe so. Unless the key on the shaft and pump gear sheared off. Might be best to test with a gauge first and go from there. I will take a look in my parts books and look in my G1000 service manual and see if there is any additional info on it for you. Does yours have a gauge (imagine it would) or a light? Could possibly be faulty gauge / sender as well.
