MM G704 4 wheel drive chain
I have my 704 split and I was wondering if anyone has ever
replaced their 4wd chain? I know it looks simple and
probably is, but I was wondering where the best place is to
get the double chain, and if there is anything else I should
know or look for? Also I would be interested in buying a
oringinal owners manuel or repair manuel.
A combine cylinder chain looks the same. It looks like a double # 60 used in many applications. Any ag store should have. Looks like shaft on right worn in housing.
I believe the shaft you are refering to as having worn the case is simply slid to the left in the picture & not in the hole.
Must have pulled stub out as they don't wear that bad. A manual of any 705,706 should be close enough.
Thanks for the replies. I think it is as easy as replacing double 60 chain... I didn't know if you had to do something special with the drop box or any tricks of the trade. Also Greg your right again, I. am always in way over my head!!
