scarylarry
New User
Hi,
I came across two round weights that say Unitractor on them with the number 117. Anybody have any idea what these are for?
Can you post a picture? Must be for an earlier Uni as I think the later ones used the same ones as the tractors did?
The ones on the Uni's have a different size center hole than the ones used on later tractors (10A373). The uni ones may have the same size center hole as the 4 hole weights used on the older tractors but the Uni weights have, I think, 8 mounting holes similar to the 10A373 weights.
Both my older repair catalogues {for the BROWN Mule (Uni)}R 2039A and the newer one R-2079 ( for No 42201684 and after w 206N engine) both indicate part No 10A16142 8 bolt hole weight. The 117 might refer to the casting number as most castings from Hopkins plant foundry that I can remember had one.
