GVI pinion gear
Tim Yates
I am in need of a pinion gear unit with the housing and good
bearings. Needs to have the constant mesh gear and the
pinion gear on the other side. If the pinion gear is damaged
that is ok. This assembly should have the pinion gear made
onto the shaft unlike the U that is on splines or on shaft with 2
key ways. 540-890-0 two four 0.
Thanks Tim
Tim, My buddy looked and he did not have one that was out either. The one from a 705 is the same. I would have the one in this complete 705. Let me know what else you find. Its alot of work to take one out of a complete tractor. 308-940-0255 Jeff
