TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: m5 hyd problems
Alan K
03-09-2013 15:49:33
Something you could also check is the coupler between the hydraulic pump and the drive shaft to it. It seems they updated them from the 5 Stars in the parts book. The 5 Stars had problems with the small coupler sleeve and the spines on the hyraulic pump wearing out. You would have to remove the hydraulic pump to check it.
pip203
03-09-2013 17:07:36
 Re: m5 hyd problems in reply to Alan K, 03-09-2013 15:49:33
The coupler is ok I just had it out when I resealed the pump. I wasn't able to find new wear plates or I would of replaced them also. The pto seems to work fine it does however creep when the pto is off. I assumed that was normal? I am pretty sure thepump is turning. Thanks for your input.
Alan K
03-09-2013 17:38:35
 Re: m5 hyd problems in reply to pip203, 03-09-2013 17:07:36
Does your M5 have an early Webster pump with one line coming out the right side? Or is it the later style with two larger lines and a small one coming out of it?
pip203
03-09-2013 18:22:31
 Re: m5 hyd problems in reply to Alan K, 03-09-2013 17:38:35
It is a webster gear pump. It has 2 lines come out of it pressurized one goes to the power steering and the other feeds the remotes3 point. It take in fluid through the center of the back. I got all the seAls at an agco dealer.
