Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: MM UTI
mmdiesel
03-06-2013 13:52:59
The UTI was an industial "U". The front axle was heavier than the wheatland (standard) "U". The tractor was made for about 20 years from 1937 to 1957. It had the 283 engine, the same as the other U's and weighed about 7000 pounds. In the 1950's the UTIL was built. This tractor had a shuttle shift and could go backward or forward in any gear 1st through 5th. Feel free to ask more questions
Michael Moeller
mmdieselpuller@yahoo.com
MM diesel
03-09-2013 18:19:33
 Re: MM UTI in reply to mmdiesel, 03-06-2013 13:52:59
Here is a picture of my 1948 UTI
rustey
03-06-2013 16:59:24
Thank you for the Info its much apprceated, here are some numbers i found on the tags
UTI 324673H
KLF 3557428F
4XX5 4 cy in the uti tag im sure if the last letter is a I or L Thank You.
rustey
03-06-2013 17:17:12
 Re: MM UTI in reply to rustey, 03-06-2013 16:59:24
Also this particular tractor Has 16-9-30 Rear tires and 15 or 16 inch front tires.
rustey
03-07-2013 13:01:11
 Re: MM UTI in reply to rustey, 03-06-2013 17:17:12
Has Any one ever heard or seen of the UTI Modle with 16-9-30 AG Tires? Also What Kind of Vaule are these worth from non running, to Good running and Good rubber? Another question My Gas Tank is Bad is The Modle U Moline Tank The same,sorry for all the questions i Dont know much about Molines Thanks
JimND46
03-08-2013 17:11:57
 Re: MM UTI in reply to rustey, 03-07-2013 13:01:11
I saved this UTI from salvage last fall for scrap value. Wasn't stuck much, rebuilt the head. Runs good now. Looks terrible. I will probably part it out if I don't find a buyer for it locally. I'm in eastern ND.
moline bf
03-19-2013 05:56:17
 Re: MM UTI in reply to JimND46, 03-08-2013 17:11:57
would you be interested in selling the clutch and pressure plate out of it. my uti's plate is cracked and no clutch shop seams to be able to fix it.
MM diesel
03-09-2013 07:49:13
What year model is this one? I noticed it has the one piece head and blocks. I have 1948 model UTI that looks very similar except mine has seperated blocks and heads. Mine has not run since 2007.
JimND46
03-09-2013 18:40:46
 Re: MM UTI in reply to MM diesel, 03-09-2013 07:49:13
According to Serial # tractor is a 1946.
rustey
03-08-2013 18:03:03
My UTI Looks similar except my front wheels look like a regular tractor and i Belive my rear wheels are differnt also.
