gettin a inject, washer sealed up
pplowboy
Got a 504 injector, copper wash,, wont seal up,,,surface is ruff an pitted,,, anyone now of the tool recut it,, clean it up without pullin , the head, i would think something like a end mill bit,might work,,,jus wonderin ,what other.deisel guys have tryed,,,,thanks for the input
Back when I worked for an Oliver dealer we had a'reamer' tha we would use to clean out the injecor bore each time we had them out. Since the tip and the end of the injector is the same if you could find one of those it might help you out. J.
Thats interesting on heating washer up...might try jus see how it works,,,im lookin for a reamer of sort that can put a new sealing surface on it....an yes mightymo the new washer ,didnt survive , 5min run time,, lol....only running on 5 cylinders , lol
(quoted from post at 03:11:29 03/05/13) Back when I worked for an Oliver dealer we had a'reamer' tha we would use to clean out the injecor bore each time we had them out. Since the tip and the end of the injector is the same if you could find one of those it might help you out. J.
Any idea where to get one?
Mike
I got some from my local AGCO dealer...they
used to be a MM dealership back in the day. I
also got some from the pump shop when they
did my fuel system.
