Yesterday's Tractor Co.
Shop Now View Cart
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: So.............What do I do now?
Underdog Moline
03-01-2013 04:03:31
If you hold the entire pushrod in the center of the main part so that it doesn't kink it but does hold it firmly you will be able to heat and remove with a pliers the solid non cup end (lifter side) once you do that you will be able to use your run of the mill tubing cutter to reduce the OAL of the pushrod to your 16 1/2" remember to add the length of the soon to be re-installed end to your measurement.
Once you have the entire pushrod mocked up place a tack weld on the end to secure it to the pushrod again and repeat!
Take your time or have a spare pushrod you can over heat the ends or mushroom them in the install remove process also make sure that the ends are on straight and that your OAL is correct before welding
Blackland Dan
03-01-2013 04:26:14
 Re: So.............What do I do now? in reply to Underdog Moline, 03-01-2013 04:03:31
This is very interesting, Underdog. I was able to remedy my situation with the shims. However, I can see that this process will be useful. It looks like a guy would be able to lengthen a rod by heating and removing both ends then partially inserting them back onto the rod and tacking in place. Does that sound logical to you?
Underdog Moline
03-01-2013 04:46:46
 Re: So.............What do I do now? in reply to Blackland Dan, 03-01-2013 04:26:14
I am not 100% sure about removing the cup(rocker) end however in theory I guess you could I know to reduce the OAL this does work and will hold up until you decided to chance your setup I maybe should have taken pictures years ago when I did mine!
