centuryfarmerplus
New User
Hi Folks,
Posted a message on this forum and fixed & welded
the sterring sector shaft on my dads brown
jet star, rebuilt the steering valve, power steering for first time in over 40 years.
Question.....I think the timing is off, replaced
the plugs, wires, points, rebuilt carb, idles
fine, when you have a load pops and misses unless
you pull the choke.
Manual says to check timing at a certain rpm
and adjust, tractor doesnt have a tachometer,
can I just borrow a timing light and try without
a tach?
thanks
Jim
you pull the choke.
a tach?
thanks
Jim
