I have a 4321 ensign carb and I am trying to build a gasket for it. The original gasket between the upper and lower halves are shrunk up and not usable. It is just a simple square gasket with 4 bolt holes i assume, until I inspect an old gasket from an U ensign carb that I have. It looks like I need to make 2 additional holes inside the ring. Or do I need to make 3 additional holes for my G because the old G gasket looks like it has 3. but im not sure because its in bad shape. I know this sound comfusing, but I hope someone who has had one of these ensign carbs apart will understand. I will post pics if needed. Thanks
