TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: live power
molinegb
02-26-2013 14:10:55
To convert back to original. Original bull pinion shaft has to be reinstalled. To do so you would need original shaft from non lpto U. Transmission housing top,fuel tank,left rear wheel,left brake assembly and left axle housing have to removed to change pinion shaft. The only other way to keep it from slipping is to weld shafts together. Usually the brake seal leaks oil onto clutch and saturates disks causing slippage. The setup is not true live as all it is doing is slipping rear drive.
