ensign R series vaporizer
1948 mm
I am trying to restore an old lp moline. I have a g set up and also a u set up, they are both ensings. I want to use the G carb because it is bigger but I belive the vaporizers are the same, but not sure, they both have a R on them. Anyway is there anyway to check these vaporizers before I try them on the tractor to see if they are any good? I did an engine overhaul and would prefer if it would start up and run right away. Thanks
