Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: g6 moline
James22
02-17-2013 09:06:00
How cold? If ambient is 40 degree F or higher it should start without too much fuss if the timing is correct and the engine is is good shape. If timing is OK, then I would suspect compression is low. I don't reuse MM aluminum pistons in a diesel rebuild if they have any significant hours. They don't use a compression ring cast iron insert and typically the piston ring lands are worn. This can lead to premature compression ring breakage and starting problems.
