| Minneapolis Moline Tractors Discussion Forum |
Topic: g6 moline
[Return to Forum]
| Author |
[Modern View]
| ryan hopkes
02-16-2013 15:24:54
96.2.96.177
hey guys i got a g6 diesel and it seems to take alot of ether to start it you have to keep sprayin it in there for like a min she is pretty cold blooded... do most diesel molines do this? or is there anything i can do to get it to start a lil more easy? it was rebuilt a while back and i had to put head gaskets in it there is no piston slop soo she isnt to tired and it has plenty of power once warmed up |
| Albert Goerzen
02-21-2013 22:08:17
198.254.191.208
Re: g6 moline in reply to ryan hopkes, 02-16-2013 15:24:54
| If its got any compression left, a tiny sniff of nose candy should start it at any temp above 40F. The tattle tale is looking at the volume of smoke coming out of the breathers when its running. There should be only be a wisp, not a steady blow. Most G6's i have been around lately are so worn out they dont have a hope of starting unassisted. |
| James22
02-17-2013 09:06:00
207.179.239.148
| How cold? If ambient is 40 degree F or higher it should start without too much fuss if the timing is correct and the engine is is good shape. If timing is OK, then I would suspect compression is low. I don't reuse MM aluminum pistons in a diesel rebuild if they have any significant hours. They don't use a compression ring cast iron insert and typically the piston ring lands are worn. This can lead to premature compression ring breakage and starting problems. |
| G1355
02-16-2013 19:42:06
67.224.60.152
| If its cold out and it has a block heater, plug it in a couple hours and that should help it some. |
| mightymolinekid
02-16-2013 15:33:52
50.105.141.149
| Moline diesels are by nature pretty cold blooded. I would check the injection timing first. Our G705 was that way, and when I changed the pump, I found it was advanced about 11 degrees. Same thing, good power but really hard starting. With the pump change, I reset it to pretty close to factory, now I don't need ether at all. |
| ryan hopkes
02-18-2013 06:02:42
96.2.96.177
Re: g6 moline in reply to mightymolinekid, 02-16-2013 15:33:52
| it misfires sometimes when its warm too could that mean the timing is off??? i was plannin on pullin all the injectors to have them cleaned beacuse thats what i thought would e cauin that problem its a really nice lookin g6 ill try to put a piture on got ind out how tho lol |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
