Brad Dixon
Recently acquired an M5. Drained Amplitorc compartment because grease was mixed with water,etc. Put diesel in to flush (as suggested in owner's manual) Ran the tractor for about 5 minutes, just sitting, not moving. Turned off and went to drain the diesel and nothing comes out. Stuck screwdriver in drain hole thinking just clogged with old grease, still wouldn't drain. Is the amplitorc compartment connected with rear-end? What would be you all's theory on why diesel not draining? Any information would be greatly appreciated. ( I plan to blow some air back through drain tomorrow, best I can thing of)
thank you
thank you
