| Minneapolis Moline Tractors Discussion Forum |
Topic: 585 Engine
[Return to Forum]
| Author |
[Modern View]
| G706
02-11-2013 20:21:33
50.39.153.211
Putting together 2-150 585 engine, going in a G1355. +.040 bore, turned crank. Got the service manual and updated specs from Welter's. Any tricks I need to know? |
| The Iron Horseman
02-12-2013 09:36:09
174.253.2.181
Re: 585 Engine in reply to G706, 02-11-2013 20:21:33
| Then all you should have to do is add the external oil pump ,oil cooler and bleeder pump from your other engine Unless yours is very very late serial number break is in the manual |
| The Iron Horseman
02-12-2013 03:36:17
174.253.4.73
| Yes there are several Depending on how early or late your 1355 is If you have a very late one it is all nuts and bolts If not you need the 2-150 hydraulic bleeder pump that mounts under hydraulic pump in rear end you also have to change the internal drive gear on pto shaft that runs the lube pump and hydraulic pump or use Moline external oil pump which is pricey and hard to find Bleeder pump is the same in 1855 2255 Ollie that is very late and white 2-105/2-150 original oil cooler line helps but easy enough to make Fuel Pump control linkage off the 2-150 is also very helpful If you want a tachometer you will need the electronic one as the 2-150 is not set up to drive one I just did mine last spring You will also need the alternator post kit for the electronic tachometer none of this is needed if it a puller only Email is open and you are always welcome to call 812-345-1301 Good luck |
| G706
02-12-2013 08:51:09
50.39.140.12
Re: 585 Engine in reply to The Iron Horseman, 02-12-2013 03:36:17
| Thanks for your reply. The G1355 was already converted to external oil pump so I have those parts already. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
