torch guy
I'm in need of a lower transmission shaft for a G900. It has the 7 tooth pinion gear on it. Let me know what you got. Thanks
(quoted from post at 18:19:51 01/28/13) I'm in need of a lower transmission shaft for a G900. It has the 7 tooth pinion gear on it. Let me know what you got. Thanks
I should have what you need. Do you want just the shaft, or do need the ring gear too?
MMDEl
(quoted from post at 01:43:00 01/29/13) I need just the shaft. What kinda dollars are we
talking?
I only check my e-mail once a day, too busy.
I will look and see if I can find it. I will give you a price then.
MMDEL
I thought I had a good loose shaft available. But they are still in the trans. and that envolves labor. Also the ring and pinion of course are mached sets and if I sell the pinion shaft that leaves the ring gear usless. I do have somes sets that I would split but they are rusty and I do not know what the degree of pressure is on the teeth.
Give me a call at 815+456-2114 and we can discuss your needs
MMDEL
