TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: MM loader specs..
c leddy
01-21-2013 20:03:25
I had a chance to measure my bucket which is almost the same shape as yours and what i found is the bucket pins at the end of the arms is 8.25" cd off the ground when it is flat. The bucket cylinder pin is 9.5" cd from the lower bucket pin. Upper cylinder pin is 35.50"cd from lower bucket pins and the cylinder stroke is close to 17" all the way extended. With this set up the bucket tips back 20 degrees and dumps 10 degrees past 90(straight up&down) when the bucket is lifted enough for the edge to be off the ground. If this helps I could actually measure the cylinders retracted and extended and you could play with string and a little geometry and try different things. With shorter cylinders you aren't going to get that much dump angle but how much does a person really need??This post may be old so hope this helps now.Cleddy
