TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: Jetstar 2 Diesel
t.r.k.
01-21-2013 19:07:17
I had a jet2 diesel for a short time. I am betting part of your problem is the injection pump has lost its prime. If I recall correctly, the one time I had that jet2 one running I had to fill the fuel tank almost completely full-so the fuel could flow 'down' to the injection pump- And then drag it in gear with another tractor for a pretty long way before the injector lines primed.
d211smith
01-21-2013 19:43:44
 Re: Jetstar 2 Diesel in reply to t.r.k., 01-21-2013 19:07:17
thats what i thought as well i filled the fuel tank and also put on an electric fuel pump before the fuel filter as well. hooked up the pump and got fuel to the injection pump but nothing out of the pump. we pulled it probably 2miles with one of the gvi's in 4th gear and only fired maybe 3 times in two miles?????? any more ideas?
Alan K
01-21-2013 20:53:26
 Re: Jetstar 2 Diesel in reply to d211smith, 01-21-2013 19:43:44
Is it a RosaMaster DB injection pump?
d211smith
01-22-2013 06:48:34
 Re: Jetstar 2 Diesel in reply to Alan K, 01-21-2013 20:53:26
i believe so i know it is a roosa master turned vertically. im pretty sure its a db series will double check later today
Dieseltech
01-22-2013 10:47:41
 Re: Jetstar 2 Diesel in reply to d211smith, 01-22-2013 06:48:34
If you like call after 7 PM IN time, 574 eight nine three four one seven two. Ask for Rich, be glad to help. Pump may have valve and plungers stuck from setting.
molinegb
01-22-2013 07:15:49
If pump is vertical it is a Roosa Master. PSB was used on early models as well as Motrac. I have a JS2 DB pump on my bench. Probably rollers stuck not giving any delivery.
injpumped
01-28-2013 11:14:18
 Re: Jetstar 2 Diesel in reply to molinegb, 01-22-2013 07:15:49
We've seen the fuel go sour in these old tractors that sit a lot, and Roosa and CAV pumps seem to be the worst affected, the plungers get stuck. Basically has to be torn down, cleaned of all the gunk, and rebuilt. I can help with this if needed. Ed.
