TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: Century M5 regulator G705
Blackland Dan
01-21-2013 18:20:31
If the pressure just shoots through the regulator,the primary valve assembly is shot. The valve is right where the gas goes into the regulator. There are 2 screws holding the valve in. Remove the screws and the valve pulls right out. You can replace just that valve. See if your LP dealer can order one for you. Just tell him you need a primary valve assembly for the M5. Just reinstall the new one. It's not adjustable. Just make sure the primary lever is properly oriented when you put it in. You'll see what I mean when you put it in.
toolz
01-27-2013 20:59:23
 Re: Century M5 regulator G705 in reply to Blackland Dan, 01-21-2013 18:20:31
Dan- I took out the primary valve as well as the small diaphragm and the main diaphragm. Didn't really find any problems other than the primary valve being dirty. Cleaned things up a bit and reinstalled everything. It works fine now and the tractor runs great. Don't know what I did, but it worked! Thanks for the tips.
