| Minneapolis Moline Tractors Discussion Forum |
Topic: MM705 Split
[Return to Forum]
| Author |
[Modern View]
| bill from scotland
01-20-2013 11:13:32
81.131.121.83
I want to split my MF 97(MM705) at the bellhousing to gain access to the clutch etc. I have a trolly frame made to support the tractor when pulling the front and back apart. Obviously I need to remove all bolts and dismantle hyd pipes and steering. Are there any other issues I need to look out for on these models or should it all be very straight forward. I know she's a heavy old thing but should she pri apart fairly easily? Thanks Bill |
| okcass
01-26-2013 18:11:04
69.8.50.90
Re: MM705 Split in reply to bill from scotland, 01-20-2013 11:13:32
| Here"s how we did our tractor. Used an engine hoist on the back, angle iron frame bolted to the front. It"s also suspended to the frame of the barn. It was a work in progress for several months, as we had to locate parts. The two parts didn"t move an inch all that time, and went back together perfectly. A shop manual would sure be a big plus with your project. |
| Jon Bottum
01-21-2013 06:27:04
50.33.171.144
| We always used a pallet jack with blocking to raise the side you were planning on moving.They were stable,easy to move and had the handle to help pull apart. Jon |
| glgrumpy
01-20-2013 11:29:20
50.129.205.26
| If a wide front, make sure to put blocks of wood or ? on each side of front axle pivot. If you don't the whole engine section will flop over to one side and possibly all the way to floor! Almost did that on my R MM first time pulling apart. I wedged blocks of wood in that space and hose clamped them a couple of times to hold in place. worked good. Use some long bolts/studs used in place of couple case bolts to glide it off and especially back on to line stuff up and go thru seals and bearings good. Studs can be up to 12" long and should be big, same size as the case bolts. Looking at 1/2 to 5/8" I assume. They wont hold tractor up, just act as a guide. Hope you have good upper support, don't rely on rafters in garage to hold! |
| bill from scotland
01-20-2013 13:00:49
81.131.121.83
Re: MM705 Split in reply to glgrumpy, 01-20-2013 11:29:20
| I have built an angle iron frame with a four wheel trolly that sits on top of the upside down angle. I have also built in an adjustable jacking system that allows me to adjust it to the underside height of the tractor. All of this should allow me to support and slide back either the front or the rear of the tractor, the other half will have the wheels blocked and a static lifting jack to keep it supported. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
