Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: Intake gasket ??s and Checked more things further
nys
01-17-2013 18:15:24
I don't remember all the details but some years back I hauled a neighbors tractor to the mechanic for him and it turned out all that was wrong with it was a screw in the points(???) was too long and grounding out somehow so it wasn't gettig spark. Easy way to check your spark maybe an inductive timing light see if it works all the time under actual conditions. Unless you ruled out spark already. You have said you found TDC by valve position seems like you could only be 180 off unless cam timing is off. I would check all the simple things first. I know you did already just triing to think of something that will help.
R Wyler
01-17-2013 19:27:27
 Re: Intake gasket ??s and Checked more things further in reply to nys, 01-17-2013 18:15:24
I appriciate all input I am to the point of using my imagination... I have pretty well ruled out spart but I will check to make sure all plugs are getting fire. I meshed the cam and crank gear according to the 1 mark on both gears just as it is pictured in the manual. But I am sure wondering if I got it wrong. One of the gears also has a 2 stamped in it I have wondered what that is for????
