Yesterday's Tractor Co.
Shop Now View Cart
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: fired once on ether.. This is odd
01-16-2013 20:26:58
think you are one hole off on timing!!!
R Wyler
01-17-2013 06:22:51
 Re: fired once on ether.. This is odd in reply to glr62, 01-16-2013 20:26:58
I located TDC lose push rods, pisoton at the top and TDC on flywheel is on pointer. The rotor is pointing more or less to the corner of the head. I moved the dist to where the points are about half open and #1 wire in cap is about in line with rotor. I have them set 153624. Am I wrong somewhere? I sure need to know if I am.
01-17-2013 10:56:42
 Re: fired once on ether.. This is odd in reply to R Wyler, 01-17-2013 06:22:51
If the points are half open at TDC you are timed way to slow.
01-17-2013 12:46:43
 Re: fired once on ether.. This is odd in reply to Captainhookerus, 01-17-2013 10:56:42
Depending if you are on front side of cam or backside,when the points first break contact is when the coil fires.
R Wyler
01-17-2013 16:58:31
 Re: fired once on ether.. This is odd in reply to Captainhookerus, 01-17-2013 12:46:43
Yes I have made sure to pay attention to the cam rotaion and lobes. I am running out hope of getting it going without getting someone out there to look at it.
