Piston Rings
JPA
New User
I took a set of M blocks to my engine shop so they could check them and order a ring set. When I looked at the Hasting part # 2C7697 the set is for a diesel I have Lp does this sound right?
Hastings builds rings for everybody. Go to their web site to check out spec"s. Blocks will give you bore size only. Pistons have different groove width"s and numbers. Also the ring type dictate the final hone style/spec. Hastings build good rings.
