MM GTS Questions
Anonymous-0
hello fellas i got a gts in the shed that im going to be getting to here in a week or so and put it together. it has the original starter but the gear drive generator is gone. was wondering if there might be one out there or at least any ideas where one may be or even a part #?? also i am looking for the side panels for the hood. thank you.
MM part # GE52. Ford # 5119. Gear has 28 teeth. Most GT's never came with electrics as they were options. A true GTS was only 1940. For some reason this was only year the tag read GTS. Mine is 160808 and other parts one has no tag. Neither had generator.
thank you for the information gb i have a question i have found a model t generator but the gear has 16 teeth not 28 like i need, i was wondering if there was a different gear out there to use instead of making one on my lathe? thank you so much
Gear appears to be specific for MM. part # FE 178B. Book also shows a no battery generator FE402 made by Robert Bosch used on 21-32 and FTA.
