| Minneapolis Moline Tractors Discussion Forum |
Topic: Re: Injection pump question
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| molinegb
12-24-2012 11:00:59
67.201.136.21
May times people have been warned to do screwdriver test on Bosch pump. These pumps have a tendency to seize the plunger in head. A screw driver used in gear setup will check if plunger is stuck. If stuck and engine cranked over shaft will snap off. This is what has happened! |
| mmdiesel
12-24-2012 12:06:58
68.89.245.25
Re: Injection pump question in reply to molinegb, 12-24-2012 11:00:59
| The tractor runs, so nothing has snapped inside the injection pump. |
| molinegb
12-24-2012 12:19:57
67.201.136.21
Re: Injection pump question in reply to mmdiesel, 12-24-2012 12:06:58
| Are you talking about rhe transfer pump gear? If so it has c-clip and a key. |
| mmdiesel
12-24-2012 13:04:08
68.89.245.25
Re: Injection pump question in reply to molinegb, 12-24-2012 12:19:57
| Yes, the little transfer pump. I will try your suggestion next I work on the tractor. I ran out of time yesterday. It will soon freeze in Texas, and i was wanting to put antifreeze in it. Instead I just drained the water. I just got the tractor last Monday, and it seems to have been neglected in many ways. Thanks |
| molinegb
12-24-2012 13:20:22
67.201.136.21
Re: Injection pump question in reply to mmdiesel, 12-24-2012 13:04:08
| There is a small special key. It is a square key with a pin that connects into shaft. I usually remove gear,clip and key to prime. If you put a cordless drill on shaft it is easy to prime rather than cranking motor over. |
| mmdiesel
12-24-2012 14:55:25
68.89.245.25
Re: Injection pump question in reply to molinegb, 12-24-2012 13:20:22
| This is starting to make more sense to me now. I turned and turned that little gear yesterday, and got no results. I realized I had the fuel valve closed. Once I opened the valve, I had plenty of fuel. We pull started the tractor, but it took about 1/2 mile (in road gear). That did not seem right. My other tractors start in about 15 feet. Do I have a pump problem, injector problems, or engine compression problems? |
| Molinegb
12-24-2012 15:21:24
96.63.37.36
Re: Injection pump question in reply to mmdiesel, 12-24-2012 14:55:25
| First two filters gravity flow. Third has to be pressurized through pump with transfer pump. I think is runs CCW.If third filter not full with no airlocks it will not run. The pump plunger achieves the pressure and side gear setup rotates plunger gear to distribute to injectors. |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
