585 custom cam
Kyle.H
New User
How much lift and duration can a 585 take, or how far is to far? Mine wrecked the exhaust valves by the gear on the crank being loose, any insight would be great, or if someone knows of a cam grinder with experience on grinding a cam for a 585, it is for non turbo pulling and 10% over stock rpm
I HAVE ONE AREADY GROUND FOR A 585 THAT WOULD WORK REAL GOOD FOR WHAT YOUR DOING GIVE A CALL 414 379 8485 THANKS TERRY
Hey Terry Thank you for all your help
Did you run that berry cam in anything?
And what model of case tractors or any tractor took the a pump that i need?
Hope you get alot of snow
Thanks Kyle
