Yesterday's Tractor Co.
Shop Now View Cart
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: MM UTS Flywheel Markings
12-19-2012 01:16:19
I am sure others would know far more than me, I am only familiar with a U. I would assume that the flywheel cannot be installed incorrectly. At worst maybe installed 180degrees off. If you pull the spark plugs you should be able to tell if #1 is coming up to TDC on compression before/when the DC-1-4 mark shows. If the U302 has the large (5"-6"?) opening in the bell housing to the clutch it should have a little notch pointer on the left side closest to the flywheel. Good luck, hopefully somebody that knows a little more about U302s can help you out if you need it.
