Yesterday's Tractor Co.
Shop Now View Cart
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: MM UTS Flywheel Markings
12-18-2012 05:47:42
You are correct about the DC1-4 markings on the other side of the flywheel. Thank you very much for the clarification.
Do you happen to know anything about how the flywheel on a U302 should be put on (i.e. DC markings lined up on bellhousing when #1 & #4 pistons are TDC or when #2 & #3 are TDC?
Thanks again for all your help.
12-19-2012 01:16:19
 Re: MM UTS Flywheel Markings in reply to JWL, 12-18-2012 05:47:42
I am sure others would know far more than me, I am only familiar with a U. I would assume that the flywheel cannot be installed incorrectly. At worst maybe installed 180degrees off. If you pull the spark plugs you should be able to tell if #1 is coming up to TDC on compression before/when the DC-1-4 mark shows. If the U302 has the large (5"-6"?) opening in the bell housing to the clutch it should have a little notch pointer on the left side closest to the flywheel. Good luck, hopefully somebody that knows a little more about U302s can help you out if you need it.
