Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: Fan hub
t.r.k.
12-16-2012 12:42:38
No. It'll grind up in a short while. I am thinking of the fan hub with the tapered roller bearings in it.
I am thnking you want a slight preload on the bearings when cold.
You have a clearance problem, Perhaps the new bearing cones were longer than the old ones. Or the cups were not as long.
You may have to put a shim behind the front cone to tighten it up.
P.S.: How did you get the rear cone out of the housing?
RS Farms
12-18-2012 15:56:52
 Re: Fan hub in reply to t.r.k., 12-16-2012 12:42:38
I pressed the front bering cone out then pressed the rear cone thru front cone housing tricky but works.No damage to housing.
Harold carr
12-16-2012 13:28:01
I think your right about the length of the cones soundes like the Problem. When I bought the fan hub assembly it was torn down with new bearings and cones in the box.
Thanks for the information.
