Yesterday's Tractor Co.
Shop Now View Cart
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: Having troubles getting the MM 602 to fire
12-15-2012 21:19:10
1. Check voltage to input of coil with switch on. Should be near battery voltage. If not there trace back to battery, if ok go to 2
2. Check voltage at output of coil to distributor. Should be battery voltage with points open, zero voltage with points closed. If constant battery voltage look for bad connection in distributor/points circuit. If constant zero voltage look for short in points, condenser, or distributor side feed through or an open between + and - posts of the coil.
this assumes you have a 12 volt - no resistor required coil. If it has coil with ballast resistor check the resistor.
Jon Pedigo
12-15-2012 21:37:12
 Re: Having troubles getting the MM 602 to fire in reply to rvirgil_KS, 12-15-2012 21:19:10
ok thanks, i have replaced the condenser and points as well but i will check the voltage in both of those areas. thanks!
