Yesterday's Tractor Co.
Shop Now View Cart
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: Jetstar with no oil pressure
Joe Pro
12-12-2012 16:37:31
How did you put rod bearings in it with out pulling the side cover off? Check your oil pump. Maybe worn, key sheared off or improper clearnaces. That tube acts as a restrictor and should be in there
12-12-2012 16:46:44
 Re: Jetstar with no oil pressure in reply to Joe Pro, 12-12-2012 16:37:31
seams odd we had 10 psi before we took it apart. And we did take the side cover off to put it back together! lol!!!
12-13-2012 07:58:47
 Re: Jetstar with no oil pressure in reply to Rustyone, 12-12-2012 16:46:44
The neat thing about this motor you can run it with the side cover off! Can see if you have any oil pressure. It will really leak out of a worn bearing. Do all of the above stuff first. Don't forget to check the pickup screen. You did mop out the sump? I have found the center main is probably leaking your oil pressure. Plastic-gauge it. They usted to make 2.5 thousandths thicker bearings.
