Yesterday's Tractor Co. New Parts for Old Tractors
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Topic: MM UTS 6V to 12V Conversion
[Return to Forum]
JWL
12-06-2012 07:58:38
69.157.9.37
Has anyone done this or know the proper procedure to complete this conversion? I have a good 12V generator off of a MM GVI that I was hoping to use on the UTS if possible but would like to know what else needs to be converted.
A detailed step-by-step procedure or assistance of any kind would be appreciated.
Thanks in advance for your help.
[Reply]   [No Email]
MMDEL
12-08-2012 07:24:16
98.213.77.126
Re: MM UTS 6V to 12V Conversion in reply to JWL, 12-06-2012 07:58:38
JWL
I took the time to check out the article you referred to. And for the most part agree with it's content. In your case you will not have to change polarity if you are using the generator off a GVI since it is positive ground the same as your U.
MMDEL
  [Reply]  [No Email]
MMDEL
12-07-2012 15:38:21
205.188.116.19
Kevin
My best guess is that your starter had A short circut in the windings that caused it to burn up. That would also explain why it spun so fast. 12V in a 6V starter is going to make spin faster ( maybe half again as fast) , but noway like an air starter. I was telling another mechanic about our discussion and he said he also has used 6V starters on 12V for 20 years or more.
MMDEL
  [Reply]  [No Email]
JWL
12-07-2012 16:59:16
69.157.9.37
Re: MM UTS 6V to 12V Conversion in reply to MMDEL, 12-07-2012 15:38:21
Thanks to all you guys for your informative input I really appreciate it and feel much more comfortable now in completing this conversion.
I recent came across an article on this website which speaks to the start debute you guys were having and I thought I would direct you all too it to return a favour so to speak.
I couldn't just add the link for some reason but it is under "Articles, then the Maintenance section, and it is titled converting 6V to 12V....."
Thanks again guys!!!
  [Reply]  [No Email]
MMDEL
12-06-2012 16:07:45
64.12.116.19
I forgot to answer your question about the distributer. All you have to do on the ignition part is make the coil changes.
MMDEL
  [Reply]  [No Email]
JWL
12-06-2012 09:11:10
69.157.9.37
Thank you very much!!! Seems pretty straight forward. Is the existing starter and distributor ok or are there any changes required to them?
Thanks again
  [Reply]  [No Email]
mmdel
12-06-2012 09:00:43
64.12.117.68
Not a real big deal. 12V Battery of course. First thing replace the light bulbs. or you will have ruined good 6V bulbs plus possibly fog up the reflectors. Then replace the coil to 12V coil, or put a resistor in between the coil and hot wire comming from the ignition switch on your 6V coil. I am assuming you have the 12V regulator mounted on your 12V Generator. That's it you do not have to rewire anything.
MMDEL
  [Reply]  [No Email]
kevin moschenrose
12-06-2012 10:58:05
50.122.11.42
Re: MM UTS 6V to 12V Conversion in reply to mmdel, 12-06-2012 09:00:43
One side note dont stay on the 6 volt starter long or you will be replacing it too.
  [Reply]  [No Email]
MMDEL
12-06-2012 16:04:12
64.12.116.19
Re: MM UTS 6V to 12V Conversion in reply to kevin moschenrose, 12-06-2012 10:58:05
kevin moschenrose said: (quoted from post at 19:58:05 12/06/12) One side note dont stay on the 6 volt starter long or you will be replacing it too.
I'm sorry Kevin, but I have to strongly disagree with you. I have been running 12V on 6V starters on many units for over 20 years. A Starter and Generator rebuilder told me back in the fifties that the windings in a 6V starter are much heavier than the 12V starters. And will last longer than a 12V starter. It makes sense since you have to use heavier battery cables on 6V because it doesn't have the push that 12V does. I would guess that anyone that tells you differently is trying to sell you a starter.
MMDEL
This post was edited by MMDEL at 16:09:05 12/06/12.
  [Reply]  [No Email]
kevin moschenrose
12-07-2012 09:35:37
50.122.11.42
Re: MM UTS 6V to 12V Conversion in reply to MMDEL, 12-06-2012 16:04:12
LOL No Del I smoked one just this year on my wd45 just this year after some one had converted the tractor over with a new starter I didn't think to look at the voltage on it. I just assumed it was 12 volt because that was the old battery in it along with the coil and new starter some one replaced. Boy did it turn fast too. Almost like an air starter on a truck.
So I based that more on experience is all.
  [Reply]  [No Email]
Heath72
12-06-2012 16:15:10
70.39.12.86
My starter guy told me the same thing Del. He's been doing it for 40 or 50 years, so I don't doubt what he says.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
