ZA Oil Pump
doc37172
Could someone educate me on the purpose of the 1/2in ball and spring in a ZA oil pump. I understand that the piston/spring assembly on the right side is for adjusting oil pressure. Is the i/2in ball the pressure relief? Can it get stuck and cause oil pressure to drop to almost nothing? How is it removed?
doc37172,
The ball and spring held in the pump body with the pin are the by pass valve. They limit the filter pressure to allow oil to flow around the filter canister if it becomes clogged. They also keep the canister from popping from too much pressure.
Changing the filter assures that this device never comes into use. I once saw a ZTU filter can totally filled with dirt and bearing frappe. The owner never knew a filter existed down there. The only passage open was the bypass hole to the intake.
Happy motoring.
Charlie at
Moline Parts
