Anonymous-0
I would like find cam for the 206 V-4 or whole motor for parts or someone to contact that would have the parts. call 605-886-8188
Hi. I dont have a cam or a motor. But I was alway curious what heads did they put on the v-4 motor. I am guessing that you have one? What is the head number if you get a chance to look Thanks for your time.
Those V engines used 2 cams. You need to tell which one you need. (I don't have one, but I have worked on one of those engines.)
Also you need to tell if your engine is L head or OHV (overhead valve), I am pretty sure the timing marks or the keyways in the shafts will be different.
The L-heads used the same block as the ZB and the OHV engines used the same block (Or about the same block) as the 445.
