kermkep
When I engage the clutch on my ztu the engine will sputter almost to the point of dying, but then will recover and run fine. Should I start looking at the carburetor or the governor? I have little experience with either. Thanks in advance.
I would check carb adjustment and spark plugs/wires. Todays spark plugs are not the quality that they once were(Chinese). The Z and R series are known for fowling plugs too. Seems like I end up replacing plugs in my R's and Z's every two or three years.
By the way, I have not had too good of luck with Champion plugs lately. I just pulled a set of nearly new ones out of my 670 Super today and replaced them with Autolites. I hope they work longer than the Champions!
I havent had much luck with champion plugs either. I ended up using Motorcraft and Autolite.
