TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: 445 timing ??
rvirgil_KS
11-17-2012 07:07:57
Original thermostat according to parts book was 170 degrees.
On my 4 Star (same engine) I used one for an 8N Ford. It is 160 degree but better than none. I have a note that gives Stant 13518/ CarQuest 31177/ Gates 33108/ NAPA 184 which are 180 degree. I have not checked any of these.
Thermostat goes in top radiator hose. Outlet end may be larger. I used CarQuest/gates hose 20791. As I recall it was a tight fit but has been on and working for 5 years. I also put a hose clamp around the hose to prevent thermostat from being forced forward into radiator.
rvirgil_KS
11-17-2012 14:21:43
 Re: 445 timing ?? in reply to rvirgil_KS, 11-17-2012 07:07:57
When installing the thermostat be sure and drill a small (1/8)hole in the outer edge of the thermostat. This will allow a small amount of coolant to circulate and bring heat up to it so it will open.
