Yesterday's Tractor Co.
Shop Now View Cart
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: G-vi rear gears
Albert Goerzen
11-15-2012 22:00:16
You make a good point. My G6 is stock, except for the fuel screw is all the way out. It makes rated power at 100 rpm over spec. (78hp @ 1500 RPM). I thot that was pretty good at 3500 ft above sea level. The 660 could make a little more but his big advantage is his super slow first gear. We are equals if he uses 2nd. If traction is not good on a given day it can go either way. As for tires, we both run 18-34s, he runs R1W radials but i dont see the advantage. I do have a set of 16.9s on a GTB that i could try quite easily. I run new Firestone 23degree on everything.
11-16-2012 03:19:58
 Re: G-vi rear gears in reply to Albert Goerzen, 11-15-2012 22:00:16
Which fuel pump do you have? If its a roosamaster, there is more than one fuel screw. The real one is down inside the pump.
