Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: 504 engines and heads I am curious??
Jeff Gravert
11-12-2012 04:55:31
The early spark ignition engines used 7 head bolt studs and then one 1/8" pipe per head that supplied oil up to the rockers. The later engines that used the 30 series cylinder heads (10A4230, 10A4231, 10A4232 etc.) had the same 7 head bolts but the 1/8" pipe was replaced with a gun drilled head bolt stud and another normal stud in the same position on the other end of the head. Hope this helps. Jeff
R Wyler
11-12-2012 12:21:44
 Re: 504 engines and heads I am curious?? in reply to Jeff Gravert, 11-12-2012 04:55:31
Thanks for the info I was curious about that.
jd plowboy
11-12-2012 10:17:39
jeff can you email me when you get a minute. got a question for you. thanks robbie
email should be open
Jeff Gravert
11-12-2012 11:46:29
 Re: 504 engines and heads I am curious?? in reply to jd plowboy, 11-12-2012 10:17:39
Plowboy, I couldnt get your email to work. Jeffgravert@msn.com or 308 940 0255. Later Jeff
Jeff Gravert
11-12-2012 11:42:24
