looking for pulling 4cly moline motor
you wanting to spend big money i built a 570 cube motor for my u 3 years ago and had 8500 in it. i got a 605 same as a 403 but just 6 cylinders that you can take the juggs, heads, rods and pistons out of and put on a u crankcase with a 6 inch crank and have 425 cubes. it has a 4 3/4 bore in it and 4210 heads on propane. you can get the 605 for 1500. you can offset grind the crank to 6 1/8 and bore the jugs to 4.810 and have 434 cubes. cheap start on a engine this way.
thanks for the info I have a 6.5 stroked crank and 4.810 jugs and pistons also have a set of 5 inch bore jugs hard block need pistons I just dont have time to put it together thanks was looking for one already together
I have a 595 CI in a 42 UTS chasis for sale. 2 hooks on new motor. Complete except rear tires, battery. All done just needs paint. Asking $5500. Call 920-420-2965.
