TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: Garden Tractor Serial Numbers
BMG1
10-25-2012 16:46:54
A picture tells a thousand words. In the early years MM changed the lawnmower every year. Later years they were the same for a couple years at a time. I think your serial number may be off a bit. The early models had serial numbers like 22400XXX. If your first digit is a 2 instead of an 8 and its brown with an drop arch front axle then its a 1962 first year model.
Brian
R Moline
10-25-2012 17:49:14
 Re: Garden Tractor Serial Numbers in reply to BMG1, 10-25-2012 16:46:54
I could be off on the serial number, it's hard to read. It is more like a sticker than a metal serial tag. I'm trying to upload a picture but it may not work. It is painted yellow but I can tell there is brown underneath it. It has a 8hp Kohler and 3 speed transmission.
BMG1
10-26-2012 13:30:07
 Re: Garden Tractor Serial Numbers in reply to R Moline, 10-25-2012 17:49:14
If it was originally brown it would be a 1963 model. If it was always yellow then it would be a 1964 model. Those foil serial number decals are a pain. They used them through 1966 then switched to a riveted on serial number tag. The 7 & 8 hp units used a 224XXXXX serial number range from the first unit in 1962 through the 1966 model year. 10 hp units used a 286XXXX serial number range. Starting in 1967 they switched over to an 820XXX model number on the tag which was the dealer order number also. In my opinion most of the value is in the condition of the foil serial number tag. You have a nice example of a 63/4 model that many collectors would love to have. I don't have one in my collection.
Brian
mm fan
10-26-2012 04:51:45
Go on and load that up and bring it to Tunica in a few weeks. Ill pick it up there.
R Moline
10-26-2012 08:37:33
 Re: Garden Tractor Serial Numbers in reply to mm fan, 10-26-2012 04:51:45
I thought it was a pretty nice little find. Don't see many at all here. The seat is the only thing missing as far as I can tell. It runs pretty good too. What's it worth?
