Uni-Matic Power LIft Cylinder
FBH44
Found out today the green/yellow hydraulic cylinder on what I thought was my old John Deere 8" disc harrow was actually a MM "Uni-Matic" Power Lift lifting jack. Got all the seals to rebuild it over at Welters. My question is, is that what I might have?? Did MM ever make an 8" wheeled pull-type disc harrow?? (No camera, sorry.)
I have one, UO is the model. Has a 4" pipe up over the frame from wheel to wheel. They called it a 9' 28 disc wheel disc, at max cutting angle angle, it cuts 8'4" according to the literature.
