Ever seen a g1355 like this
G1355
Have this original mm g1355 brochure and it has headlights in the grill and says mm, and the rear fenders are rounded out and are painted yellow, dont know what year this one was made but looks differant compared to the others i have seen, anyone have one or seen one like this I never have and was hoping someone could post a picture of one like this if they have one it would be greatly appreciated. Thanks
I have seen that one before and noticed those differences as well. I don't think that any of them came with lights in the grill like that. The MM is right for it as the 73 models had MM and the 74's had yellow side panels and "WHITE" in the grill. The yellow on the cab fenders isn't like any real ones either but the cab is right. When it comes down to it it is just some artists drawing of a G-1355 and as with many of the other brochures especially the 50 series what they drew and what rolled out of the factory are not the same. Here is a pic of a 73 and 74 model for you to see the differences.
I have the brochure of the top one to, like that one the most
the fender fuel tanks look sharp too
Here were a few 1355 pics I took at the Bridgeport auction:
<a href="http://s130.photobucket.com/albums/p268/case600lp/permanent/?action=view&amp;current=DSC_0097-1.jpg" target="_blank">
DSC_0097-1.jpg" border="0" alt="Photobucket
</a>
<a href="http://s130.photobucket.com/albums/p268/case600lp/permanent/?action=view&amp;current=DSC_0105-1.jpg" target="_blank">
DSC_0105-1.jpg" border="0" alt="Photobucket
</a>
<a href="http://s130.photobucket.com/albums/p268/case600lp/permanent/?action=view&amp;current=DSC_0034-2.jpg" target="_blank">
DSC_0034-2.jpg" border="0" alt="Photobucket
</a>
Howard
And here is a mod I'll bet not too many people have seen. It was a pretty neat conversion in some ways and pretty ragged in others. Overall, the tractor hadn't been used much.
I bid on it a while back, but didn't get it:
<a href="http://s130.photobucket.com/albums/p268/case600lp/permanent/?action=view&current=DSC_3862.jpg" target="_blank">
DSC_3862.jpg" border="0" alt="Photobucket
</a>
<a href="http://s130.photobucket.com/albums/p268/case600lp/permanent/?action=view&current=DSC_3866.jpg" target="_blank">
DSC_3866.jpg" border="0" alt="Photobucket
</a>
<a href="http://s130.photobucket.com/albums/p268/case600lp/permanent/?action=view&current=DSC_3863.jpg" target="_blank">
DSC_3863.jpg" border="0" alt="Photobucket
</a>
Howard
Thanks for those pictures. Don't know how anyone could let the one look like that, I just love these 1355 especially the diesels, very sharp looking tractors and I have never seen a loader on one before thank you much for sharing
A DETROIT??? Big muffler or not I bet that one talks. Was the propane tank converted over to diesel?
Bryce
All these beautiful G1355 pictures, I just can't help myself. Here's my G955 i acquired this past spring. I've finally rounded up all the parts I believe I need to make it run, just waiting for some time to work on it.
Casey in SD
Yes - you can see the fill pipe they stubbed into the top - that was part of the "ragged" conversion...
I wondered what they had done to it to have to replace the motor with so few apparent hours - the drawbar had almost zero wear on it... Same for the three point hooks...
Howard
The old girl needs a starter, ring gear on the flywheel and the radiator fixed. The tractor lived it's life on a irrigation pump down by Whitewater, WI. Never pulled a load a day in it's life, all pto work. It was bought new by Lurvey sod farms. At some point someone put the wrong starter on it and it chewed up the ring gear. They continued to push start it for a year or two and then parked it. I have family who works there and when it was gonna go for scrap they called me, so i ran down there and rescued it. While loading a fork slipped and took out the grill and poked the radiator. I'm not sure yet if i'm gonna fix it and leave it alone or make a puller out of it. Time will tell.
Casey in SD
It will be fixed either way, just can't decide if I want to make a puller out of it or not. I want to get it going this winter but I might have to tear down my 766 IH instead. It has developed a unknown sound in the rear end 8( One at a time is about all time allows for around here.
Would like some more information on the tractor with the detroit motor in a 1355. I am very interested. You can give me a call back at 402-380-8701.
Thanks
Loy Woerman
