3 bottom 3PT. plow
Anonymous-0
I will attempt to post a few pictures of this little relic. What colors should it be painted and where can I get decals or a stencil to put the proper lettering on it? Thanks in advance.
Here are some pictures.I want to know what color to paint this implement and where to get decals or the correct stencil. Thanks
Moline called that plow the M550 series. As you know it is a late model Oliver 3241 plow.
You can get the correct red paint from an AGCO dealer, but if it was mine I would use the ford tractor red that was used on their tractors from 1958 to 1964. As for decals, again if it was mine, I would go to a decal shop with the correct measurements, and have them made. Probably a lot cheaper, too.
The Decal is a 2X29 1/2 inch Yellow Block letter decal. I thought R-M Distributors 712+677-2491 had them, but I don't see them listed in their ad. I have some call me at 815+456-2114. It is one long decal, on that application because of the bolts in the way you have to cut the decal into and place them as you can see on your plow.
MMDEL
