gvi rear end bearing
billy39
New User
Does anyone know the part numbers for the bearing and race that gets pressed on either side of the ring gear? The race is missing out the pinion cage in my project tractor and im hoping to get just a race for now the bearing is ok and i dont want to remove the diff at this point in the build.
They are different on each side, One is wider.Seems like the number is 597? I would have to look to be sure.
If the cup is chipped up, the inner cone is probably failing as well. Best do it right so you won't have to do it again.
When I ran into that on my UTS I was able to get the cone off the pinion carrier while it was still in the case. I used one of those pullers where the jaws slide back and forth on the bar the screw goes through. It was a pretty big puller though.
Its not chipped its gone. Like missing gone. Bought it from a guy who had been working on it and it was torn apart with some pieces missing.
