UTN rear wheel weights
redgems
Can anyone please identify rear wheel wt # 10A373 is it correct for a Ut.or UTN
Also one weight has #10027x below the #10A373 is there any difference?? They look the same.
Any information is much appreciated. Thanks,Tony
This is one of the correct type centers for the weights.
I use 3/4" threaded rod on my tractors. 2 bolts or rods on each side will hold quite a few weights. There are 4 holes in each weight and each wheel center also has 4 holes. Another similar weight has part # UT518, but I think those only have 2 holes.
Here is what the weights look like on the tractors.
Correction: the 10A373 weights will have 8 holes, and the UT518 weights have 4 holes. You can see a UT 518 weight on the restored tractor (1956 UB special lp) The back tractor is 1954 UB diesel.
Yes, the 10A373 weight is correct for a early fifties U. Those weights came out around 1949, and were the updated version of the UT518. They were used for many years.
