G707/G708 Air Cleaner
Anonymous-0
Does anyone happen to have a photo or picture from a parts manual or something that shows how they mounted and routed the inlet and outlet pipes from the air cleaner on a G707/G708 with the horizontal air cleaner. We would like to put an actual air filter housing from a G1000 tractor on our GVI as oppose to putting the old oil bath filter back on. I know some modifications/engineering will be involved but a picture of how they did it on the G707/G708 would be helpful.
Thanks in advance for your help.
Photos from under the hood showing how the inlet and outlet pipes are routed as well as how the air breather is mounted would be very greatly appreciated!!!
Thanks in advance for all your help.
here's some pics...
Thank you very much for the photos!!!
Would you be able to take one of where the air filter canister mounts to the side of the engine?
Thanks again for all your assistance I greatly appreciate it.
It's dark now, but if I remember right there are two bosses on the bottom edge of the head that have threaded holes in them. There is a flat plate that bolts to them and the canister clamps bolt to that.
